Software used: AECOsim Building Designer V8i
OS: Windows 10
Question 1:
I am using i-model ODBC to see the different tables (e.g., pipe, door, etc.) in Excel. In the tables, I see three different IDs: Element ID, Mstn ID, Instance ID. I understand what Element ID is - it's the ID I can see when I select an object and click on Element Information, but I've never seen Mstn ID and Instance ID before. How are these three IDs different?
Question 2:
When I use i-model ODBC and see different tables (e.g., pipe, door, etc.) in Excel, some tables have an Element ID column and some tables don't. Is there a way to change some setting so I can see an Element ID column in all of the tables?
Thank you everyone!
Min
Hi Min,
it's recommended to ask questions separately to don't create confusing threads with merged topics.
My guess about different IDs:
Element IDs are displayed only in tables relevant to MicroStation elements. Other tables contains business data not relevant directly to particular element, so in such case there is no Element ID. How tables are created and in what structure depends on an application used for i-model creation, so export from MicroStation will be quite simple (and probably Element IDs will be everywhere), but from AECOsim BD or Plant products will be more complex.
With regards,
Jan
