Hi all,
In excel you used to be able to select an imodel to extract data from. This worked perfectly. In excel 2016, you cant select a file, but rather point to it - this doenst seem to work anymore though, any ideas?
CheersIan
Hi Ian,
Please take a look at this pdf document with the information needed to use iModel ODBC driver in Windows 10: https://communities.bentley.com/other/old_site_member_blogs/bentley_employees/m/bentley_employees_gallery/272795
Hope this helps,
I've needed to remove the file as it was on an unfinished state. I will upload a new one as soon as it was finished.
Hi Eduardo...is the document finished? I'm running across this very situation. Windows 7 we can get it to work. But I can;t get it to run on Windows 10. Thanks.
