Hi
Hello
I'm looking for a way to download an older version of Bentley View
I am looking for the version Bentley View SS3 ( SS4 not working with AUTOCAD 2013 -> import is explosed )
Thank you
If you have a SELECT agreement please submit a Service Request.
Alternatively you can download the needed RealDWG version you need and set the application to use that version, see the following:
https://communities.bentley.com/products/microstation/w/microstation__wiki/12387/how-to-download-autodesk-realdwg
https://communities.bentley.com/products/microstation/w/microstation__wiki/26565/enable-realdwg-2016-update-for-dwg-20152016-format-in-ss3ss4
