Hello Everyone,I would like to report a problem that came out in MicroStation Connect v10.9.0.24.
I have a .dgn file with 1 design model and 3 sheets completely identical that contain the master model attached as a reference. In this file I imported the AutoCad Line Style and setted the lines scale.
When I do the export in .dwg everythings works fine, except for the fact that when I open the .dwg file with an Autodesk application (AutoCad, DWG TrueView, ecc.) I see the correct line scale only on the first sheet exported while on the other 2 sheets I see a incorrect line scale (Please refer to the file attached SHEET_PROBLEM.dwg).
But if I do the export 1 sheet per time (master model + sheet, not export sheet as separate file) I see every single sheet perfectly (for i.e. see the file Sheet_2.dwg where I exported only sheet 2).
It seems like the export works fine only if I export 1 sheet per time.
I think this is a bug, let me know if you are able to reproduce this behavior or if this is just my problem.
Thank you in advance.
SHEET_PROBLEM.dgnSHEET_ PROBLEM.dwgSheet_2.dwg
Sorry for the delay in response to your issue. When I open each of the supplied files in either MicroStation CONNECT or Trueview the line style scale looks the same to me. Maybe you could supply some screen captures to show how this appears on your system between the two packages.
Hi Andrew,
this is what I see in DWG TrueView:
I tried to open this files on different PCs with different versions of AutoCad, Trueview and every time I saw the line styles on sheet 2 and 3 incorrectly.
In MicroStation CONNECT and v8i I see the lines perfectly.
Best Regards,
Matteo Sodomaco
I had a look in AutoCAD 2018 and the line styles look right in both dwgs.
