Can someone tell me if it is possible to convert Microstation *.POD Point Cloud Data to *.LAS file format?
I have seen another user do this using Microstation Connect however the option does not seem available to me using V8i. The only export i seem able to do is to *.XYZ, or *.POD
Thanks in advance,
Russell
V8i was limited to exporting to POD and XYZ format for export. CONNECT Edition based products can export to LAS.
