Hi
Is there a variable to set the default directory for exporting DWG-files to in Microstation connect? I've search trough this list but I can't seem to find it: https://communities.bentley.com/products/microstation/w/microstation__wiki/24873/microstation-connect-edition-configuration-variables
For IFC it's: IFC_EXP_OUT and for DGN it's MS_DGNOUT but it seems there no equivalent for exporting DWG:s.
Robert
MS_DWGOUT
Duncan Macdonald said:MS_DWGOUT
I'm sure you're right, but a search of MicroStation CONNECT help for MS_DWGOUT reveals nothing!
Search Results for "MS_DWGOUT" 0 results in 3.922 seconds
Doesn't appear to be documented but does appear to work.
Thanks, but it don't seem to work for me. Don't know if it's because of that varible, or because I have my workset set up like this. (Reason is to only need one workset).
_USTN_worksetROOT = $(_DGNDIR)../ MS_DWGOUT = $(_USTN_WORKSETROOT)Modell/DWG
Hi Robert
I don't see why that would stop it working. The only reference I can find to it is in a variable list from 2003.
