I'm trying to export a file to SketchUp in order to do some additional modeling. It is a water channel realignment and has countours and i get to around 37% and microstation just closes spontaneously. Has anyone experienced any similar issues and if so any fixes? Any limits on what can be exported to SU? The drawing has about 8 reference files that link to different aspects of the alignment.
Not much experience with SketchUp. If SU is capable of importing a different format like DXF, you could try that. Also check export setting for SU is handling the references appropriately.
Hi Nick,
in general, SketchUp export should work.
Can you provide more details about MicroStation version you use (because V8i spans several versions and several years of development), e.g. MicroStation build number?
What you can try to narrow where the problem can be:
With regards,
Jan
