Hi every one
I'm looking for the best common fonts lines and units sitting so the drawing can be used with both microstaion v8i and autocad or autodesk without toning the sitting or modification needed gust open and continue working
thanks for the replies what about lines level and units???
Microstation can read and use AutoCAD linestyles, so if you want the most seamless transition, you may want to save your AutoCAD linestyles into a DGNLIB or a Seed file.
MaryB
thanks Mary B for the replay but I think there will be some difference in the thickness of the lines
Where do you set thickness in DWG line styles? Don't we call it line weight and it is a own DWG CAD attribute.
Frank
