I had a newer version of v8i installed and it works better on acad files but I still get the message about missing enablers. The image shows what I am talking about. The message doesn't have anything to with the SHX fonts, does it?
Anyway how do I get more Object Enablers into this newer version of Microstation?
ss4 ver. 08.11.09.832
Thank you
Remember that the OE that yo need to install is based on the version of RealDWG that MicroStation uses to open files. From the version number you provided that would be RealDWG 2016.
See the following:
https://communities.bentley.com/products/microstation/w/microstation__wiki/4177/realdwg-tm-tn
