I would like atool to load when starting microstation. I add the atool.ma file to the MS_DGNAPPS configuration variable. It loads but there is a dialog box issue.
I go to toolbox uncheck it and then recheck it and I get the error
Unable to load dialog whose id is 70.
Any ideas on the fix?
Andrew
Hello,can you specify the MicroStation version (XX.XX.XXX.XXX) you are using?
What is the 'dialog box issue' you are having- can you explain what is happening?
Derval Canny.
Hi Derval,
Turns out our DOT's custom menu did not have the ATool.dll, just the ATool.ma. I downloaded the latest Atools for V8i and now have the dll. All working now.
Hi Andrew,
good to hear that all is working now!
For anyone else looking for this tool, it can be found at the following location:
https://communities.bentley.com/communities/other_communities/bentley_library/m/bentley_library_utilities
