Attaching an LAS file downloaded from NOAA.Tried all the settings I can think of, but the point cloud will not attach at the correct coordinatesIt does have an "Invalid WKT" message in the attach settings, but if I try to change the coord system I get a "Not Possible to Override the file GCS".Moving to CONNECT so I need this figured out, can't keep going back to SS4 to attach point clouds.
Tom F.
Tom Felcone said:the point cloud will not attach
Which version (e.g. v10.x.y.z) of MicroStation or other product are you using?
Jon Summers said:Which version (e.g. v10.x.y.z) of MicroStation
Jon, in forum title "CEU10". So at least Microstation CE Update 10 is being used.
José
-bump-
Hi Tom,
Could you please upload your file using this link so I can review it https://bentley.sharefile.com/r-r2544dd11fde401d9 ?
Maria, Files uploaded, if you need anything else, let me know. I have not checked this in CEU11. Thanks for looking at this. Tom F
