Hi all,
I've found that DWG export entity mapping doesn't seem to work in CE (and the later versions of v8i).
Has anyone else experienced this?
Mark
Mark, Can you please provide the product and the version of the product that you are running, and also a more detailed explanation of what you mean by entity mapping does not seem to work ?
Hi Melissa,
I am referring to the Entity Mapping Options in the DWG export settings. Mapping to 3D solids, polylines, etc. haven't worked for all applications we have attempted them on and it is very much needed.
We've used Microstation v8i SS4, MX v8i SS4, Microstation CE U10 and OpenRoads Designer U5 and it produces the same result (no change.
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
which entity mapping options do not work? We have tested the first one "Planar Line strings" in CE U10 set to Polyline and that appear to have mapped the entity correctly. if you can specify which options do not work or which options you use we can then test them here and verify whether or not the issues can be reproduced. .
if you can also provide a sample data file this will also help with testing.
Attached is some sample data. No matter what I do, I get "default" mapping to the element types below. From this I believe Entity Mapping is not actually doing anything. It seems that this is also the case in older versions all the way back to v8i, but I haven't had a chance to test this.
eg.
Linestring (2d) = Polyline
Linestring (3d) = 3D Polyline
Mesh (closed) = Polyface Mesh
Mesh (flat) = 3D Face
Solid = 3D Solid
Complex Shape = Polyface Mesh
Shape (3d) = 3D Polyline
etc.
test-mapping.dgn
test-mapping.dwg
