I would like to export each element as a seperate .fbx file. Is this possible without putting every object on its own layer?
Kind regards,
Luke
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
AECOsim Building Designer V8i (SELECTseries 5)
You can create a displayset where just a single 3D element is displayed and export to FBX so only that element is processed.
To automate this process to process all 3D elements individually would have to be done through some VBA programming.
