Importing .dwg files v2018, even after converting everything to solids (and saving to 2014 version) results in objects all over the place. Mostly shifted in the x,y and sometimes z axis. Is this normal? I would be grateful for any suggestions. - plj
Maybe you had the same issue as "Microstation v8i SS4 range issue for a dwg file"? If so, see if your V8 product has a newer release which is built on PowerPlatform containing the ACIS transform fix discussed in other old posts.
