I have both MicroStation V8i SS4 and PowerInRoads SS4 installed on my computer.
I am only able to save and open DWG files up to version 2009.
Is there a way to update my version of RealDWG to allow for reading and writing DWG 2012/2013 formats?
Hi Rod,
Microstation SS4 include Autodesk RealDWG 2016 Support. See image below
You should be able to change the version to 2013/2014/2015/2016
Maria Garcia
I understand that, but my list of available versions in that pop-up menu stops at 2009. Hence, my post here.
I tried setting MS_REALDWGVERSION = 2013, but I still couldn't open anything later than dwg 2007/2008/2009.
Rod WingSenior Systems Analyst
Review this wiki article https://communities.bentley.com/products/microstation/w/microstation__wiki/26565/enable-realdwg-2016-update-for-dwg-20152016-format-in-ss3ss4
Set variable MS_REALDWG_VERSION with new value 2016
save all the changes, exit and restart MicroStation
If this does not help review how to download Autodesk REALDWG2016 https://communities.bentley.com/products/microstation/w/microstation__wiki/12387/how-to-download-autodesk-realdwg
Maria
