DWG to PDF
Hello all,
I am using microstation v8i and I am facing a problem in converting several dwg files to pdf.
Is there a way or software to select several files to be converted other than opening each file and converting separatly?
  • Do you mean printing them to PDF? You can do that with the Print Organizer. Create a new Print Set, add the drawings you want to "convert", and get the settings the way you want them. Make sure you use the correct plot driver/plot configuration to generate PDFs to your company/client standard.
    When you get ready to print the Print set, you will have the option to create one combined PDF, or single sheet files.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
