HI
When I export to DWG some of my pattern disappears if I choose to use the fence as filter. I have the exact same settings in both cases, except of the fence. I also tried placing a gaint fence really far zoomed out, but it didn't help.
Export with fence:
Export without fence:
How could this be?
Running AECOsim connect update 4, equal to microstation connect update 11.
Robert
While I have no actual knowledge whatsoever...
Is this the only drawing this happens to, or does it happen to all your drawings?I wonder if there isn't some pattern control element that's getting clipped "off" by the fence.
MaryB
I'll try and get back to you on this.
That was one of my thought as well. That's why I created a giant fence, but that didn't work either.
Do you see the same issue if you do fence copy?
Hi. No I actually don't. Seems there must be something with export settings then(?).
DWG SaveAs Options has a View number. Have you set that to the view where you placed the fence?
