I received some files from contractor (he's using some older version of Acad) and during opening or attaching as ref file I'm getting this error message >
The NLS files are not found to convert text entities from the DWG codepage 45!
I haven't found any relevant info on the net for codepage 45, could someone please share some light what codepage is it and what language shall I add to my system to clear this message?there are also lots of warning messages about linestyles may have not complete data, is there a way to fix it?thanks
Hi Peter,
is it possible than the file was created with a different language than English? if so you could add such language to Windows control panel\Languages, Regional Settings
