We produce 3D models of electrical cabinets in Inventor which produces a ACAD 2D drawing. Our client requires all work as dgn's. I have tried to export as a dgn from ACAd but this is not working because I assume the information is a reference to a 3D model opposed to vectors. I have also tried saving the ACAD file as as 2007 version and this does not help either. I have attached what it should look like if the process worked (this was created by attaching a pdf as a raster over the title block).
Some issues have been the table of materials can not be edited, the bottom view comes in as a duplicate of the front view but a smaller viewport and one cabinet show an isometric view overlayed with a orthographic..
Can anyone offer any suggestions? I have spent a lot of time on this and have got nowhere. We do not want to just redraw everything into microstation as this is not an accurate method and it will not reflect the 3D model.
Thanks in advance!!
David
PDF
Hi, I assume the dwg you created is looking good when you open it with Microstation or ACAD? what Element Types have you got? The attached pdf is created at which step of your process?
Could you attach the dwg?
I have seen the issue of the smaller Viewport. May be an issue with the scale vs. resolution (for a while I suspect the Resolution/Units of the Default dwg-SEED provided by microstation could be responsible for this kind of behaviour)
ACAD and Microstation appear handling references and "Viewports" differently" DWG with sometimes strange behaviour.
Editing of the table (if that is a shared cell) can be resolved by dropping the "shared cell" to a normal cell, If the Texts are tags you have to first drop them into text with the keyin: CHANGE TAGS DROPTEXT
I prefer keeping the referencing but Merge-into-Master (ReferenceDialog) may be a last Resort to get a good looking (yet low-level) Output.
I hope that helps you to get ahead
080-E-13715_0 trial.DGN080-E-13715_0 (DC350 GA1)007.dwg
I am trying to get the DWG into the dgn environment attached. I do not have a lot of experience with microstation as I come from an ACAD back ground.
Thanks for any guidance.
The issues stem for one from the export and two from the limits of DWG blocks (called shared cells in Microstation)
The Display issue presumably is originating with the Export from Inventor to DWG. All Elements seem to come over on the same Level "Visible(ISO)"
-To resolve the issued with MicroStation V8i open the DWG in MicroStation V8i and "Save As" > V8-DGN.
-To be able to edit the Table in the Layout: Main menue> Drop Element (with the Settings: Shared Cell > to Normal Cell)
-In the Model drop the Shared Cells/blocks (The draft elements) to Normal cells. Then move one of the cells to Level e.g. "H".
Back in the Layout > Level dispay dialog[view]: in Viewport 2 Switch off level "H" in Viewport 3 Switch off level "Visible(ISO)" (or the other way around)then you should get what is shown in these two files:
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/19567/080_2D00_E_2D00_13715_5F00_0-_2800_DC350-GA1_2900_007A_2300_Layout1.pdf
080-E-13715_0 (DC350 GA1)007A.dgn
Thanks a lot the table issue worked and the model reference I have resolved I didn't really follow what you meant but just copied each cell from the converted dgn and then scaled it and put NTS. The dimensions have to be a set standard for the client so I just re-dimensioned all of them.
Very good of you to help.
