DGN to DWG Text with annotation scale from mstn gets all screwy
V8is4 Lately when I export some dgns that have used annotation scale I get tiny or no text at all when I open the DWG, even though I tell the options to convert msnt fonts to SHX.. what am I missing
never had this problem when we didnt use annotation  scale...
  • Hi
    DGN and DWG Text with annotation scale is not comparable. And I even did not read anything in the docu how DGN annotations are converted to support DWG's different scale options (text size for multiple scales  and even multiple text positions)
    But there some posts here around.
    good luck
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
