Hi all,
I have a question re multiple sheet sets. They are DWG files, saying sheet 01to02. When I open, they are only the one model, one view. No multiple sheets.
If I open in AutoCAD, the same. I thought sheet sets were .dst
Appreciate its a Microstation forum, but I am more comfortable using Microstation vs AutoCAD.
Any tips?
Cheers,
Andre
Would you be able to clarify whether your issue is related to Sheet sets defined within the MicroStation "Sheet Index" or if it is something that has been defined within AutoCAD?
Hello Andrew. From what I can gather, there is just one model, containing one set of information. Not sure where the other sheets are. They are dwg files, so possibly set up there,but not a sheet set .dst, and no extra views.
Appreciate the reply, not sure how to tackle this
If you could provide details of the version of MicroStation you are using along with the file, or at least screen captures to show what you are talking about, we can then try to understand how this can be investigated.
Hi Andrew,
I will provide further details re software versions and screenshots Thursday when I'm back at work.thankyiu for the feedback so far.
andre
,MCL-ET-11397SHT01 TO 08.dwgMCL-ET-11444SHT01 TO 011 REV 5.dwgMCL-ET-11445SHT01 TO 06.dwg
Good morning Andrew.
These are the files, they are meant to contain multiple sheets of information, but I can only find one sheet(view/model) in each. No matter how I look or open in both Microstation or AutoCAD, I cannot extract or separate them, if indeed there are individual sheets. I am using Autodesk AutoCAD 2018 and Bentley V8i Select series 3
Any help would be greatly appreciated and privacy of documents also.
many thanks,
