Hi all,
I have a question re multiple sheet sets. They are DWG files, saying sheet 01to02. When I open, they are only the one model, one view. No multiple sheets.
If I open in AutoCAD, the same. I thought sheet sets were .dst
Appreciate its a Microstation forum, but I am more comfortable using Microstation vs AutoCAD.
Any tips?
Cheers,
Andre
Hi, if you see the same in both mS and aCAD that is how the files are created. I am only have TrueView from AutoDesk which Shows just the same. I guess you should ask the originator how the files are generated, from where and what they are really "meant to contain"
Need help for the selected function? Click into the "Toolsettings" dialog and press F1 For Screenshots try Win+Shift+S on your Keyboard - I am using "ScreenRecorder" for Videos Brauchst Du Hilfe zur gewählen Funktion? Klicke in das "Funktionseinstellungsfenster" und drücke F1
