I am exporting my DGN Drawing models to DWG with a Wireframe Display Style and noticing this is the Visual Style that is set in AutoCAD. Unfortunately this does not display certain elements and I require to switch the DWG to the "2D Wireframe" Visual Style in AutoCAD.
Does anyone know how I can get my DGN Drawing models to export to DWG with a "2D Wireframe" Visual Style?
I'm using Microstation CE U12 and OpenRoads Designer U7.
Mark
Surely must be some way? Can I create a custom display style with particular settings for this?
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Will setting the desired parameters in Wireframe in ACAD and saving the file as your seed DWG file be acceptable?
