DWG export settings
I have a Dgn file which contains a sheet and a design model. The design model has 2 references attached and I then create 3 saved views. The saved views are attached to the sheet with live nesting enabled. When I export the file to DWG, the display is incorrect; the nested refs are not visible yet in the design model they are visible having been merged to cells. Does anyone know what DWG export settings should be enabled to have the Dwg sheet view match how it appears in my dgn file?
