Losing AutoCAD Reference Info
This is the second time I have had this problem is a couple of weeks. Hopefully someone might be able to give me a lead on how to solve it.
I have a survey drawing that was created in AutoCAD 2004. I referenced this file into Microstation to create a base drawing from which to create cut sheets for my project. I then created my cut sheets, referencing in my base.dgn and turn on Live Nesting because of the AutoCAD reference that is in the base.dgn. After having created all of my cut sheets, then working on other projects, I come back to this project and pull up my cut sheets only to see the reference info has disappeared, and in every cut sheet! I open the Reference dialogue box and see that my reference is still there and seems fine, but it will not reappear or give me any kind or error message upon opening the dgn. I try reloading, still nothing. My only option has been to re-create all of my cut sheets. Can someone give a clue on what might be going on?
 Thanks!
