In Aclt I could move lines to back or forward. I tried to find instructions, I could understand on doing this. I have attached the line and picuture
I want the green line behind the magenta line, would someone assist in simple engilish for a rookie, please I went to the Power Select and found the tab
display priority, but did not seem to get it to do anything.
I had t his, but cold not seem to get it to do any thing for me, Thanks
If possible reply to rphillips@Logicalsysinc.com I am on line there now.
there are 2 options >
select elements, use Edit | Bring To Front menu command. there is no "Bring To Back" command so you have to choose right elements
other, more sophisticated way is to use Display Priority values. the lowest one is -500, the highest one is +500. so you can have 1000 individual "levels" to place elements on. the only condition required for this concept to work is that file is 2D.
in 3D file (which is usually any opened DWG file, unless you specify it in DWG | Option dialog - see attached screenshot) this concept does not work and the display of elements honor the real ViewZ value. the Display Priority picker in Attributes toolbox shall be grayed in such case
HTH
p.
/pt
