Can MS run acad lisp routines?
I am looking into ways to help our acad users migrate somewhat into MS. We will be beginning a pretty large project soon and we want to use all of our personel available which means our acad users and I'm gathering as much information as I can for acad users to better understand the things MS does. I have setup a preliminary workspace using the DWG/DXF variable and it seems to work pretty well. I haven't used acad for a very long time! I think it has evolved, along with MS, and as I think of our acad users, the thought of lisp routines came to mind.
So, can MS run lisp routines? Much of my searching tells me no, I"m hoping against hope but you can't get answers if you don't as quesions, right?
Thank you
  • Your research is correct on this matter
    Answer Verified By: JDJATKHA
  • I dont think that ustn can do that..
    However if you know what they do,  you can work out a work flow then create a macro or vba macro to do the same
    If the acad lisp was VBA you could probably modify them to work..in ustn.
    but first work out what they do..
    Also in the help under working with dwg there are about 4xA4 pages of acd to ustn function comparison of commands you can print out and give out to your team...
    you can also teach you guys to keyin dwg and look at the keyin window for various acad commands then when they run those the right ustn icon command dialog pops up this is good way for acaders to learn or transistion from the dark side over  to microstation...hahaha!
    Lorys
    click link to PM me
  • That said, many of the LISP programs I have seen in the interaction with A-CAD users, didn't do very complicated things. Many can probably be recreated in M-Sta. as a series of key-ins that can be placed on a button or function key, a Scrip (.txt) file, M-Sta Basic (.ba .bas) or VBA programs without much effort. As Lorys stated, Find out what they do and then pick the simplest ones to start customizing in M-Sta. If they do complicated things you may need to do VBA or MDL programming to accomplish what the LISP did, but I doubt the majority are that complicated.
    I Hope This Helps Someone Reading This!  (Intergraph>PseudoStation>MicroStation user since 1980's)
