In autocad I had a Leader command and I do not know the term in Microstation, I have done searches in the F1 help and searches on this web site, but all I need is what Microstation calls there command where you get an arrow head as a pointer and you can also put in text? I am sure this has an easy answer, but I wasted quite some time trying to find it. Please help
I have since been given great help. I was able to use place note, make a space and put in the arrow point and Line I wanted. I did like the suggestion as well "Type in DWG and the Aclt command. Example DWG Leader and it showed the Bentley equal command.
RJB Phillips III - Praise the Lord for His Mercy and Grace
Answer Verified By: RJB
