Hi all
How I can read element_id property from i-model using i-model odbc tool?
This app "i-model ODBC Driver" will help. Get the download from here:www.bentley.com/.../imodel+OBDC+Driver.htm
I 'm using that odbc driver and reading succesfully all needed data to access database tables, but still missing the element_id from microstation elements. I think there is no such a property like element_id in schemas you can read. With i-model composer tool I can see element_id.
Which dataset are you using, and can you get Element_IDs in Items Grid as EC Properties in Bentley i-model Composer? If you may please send me the simple test case @ Junaid.Khan@bentley.com
