Just a footnote on this MDL. I have upgraded from V8i ss3 to AECOsim Building Designer V8i ss4 version 8.11.09.593 and this MDL no longer works in DWG files.
Lincoln
The discussion has been split from the following:
communities.bentley.com/.../91507.aspx
It is in relation to an MDL written to perform this operation in a DWG but does not work in AECOsim Building Designer.
communities.bentley.com/.../139145.aspx
What's the last version/product on which it has worked?
Hi Don,
As if the Forums were not confusing enough before :)...
I just checked with MS ss3 8.11.9.459 and this MDL still works on this version of Microstation.
