The MicroStation product team is pleased to announce the availability of MicroStation PowerDraft CONNECT Edition x64 Update 4 (10.04.00.49) on Fulfillment Center and for update through the CONNECTION Client. This version of MicroStation PowerDraft CONNECT Edition incorporates a number of new capibilities as well as user requested fixes. Please refer to the "What's New Highlights" section below for some of the major product updates and enhancements.
If you have MicroStation PowerDraft CONNECT Edition already installed on your machine, you can download and install MicroStation PowerDraft CONNECT Edition Update 4 from the CONNECTION Client. MicroStation PowerDraft CONNECT Edition Update 4 will update previous versions of MicroStation PowerDraft CONNECT Edition to MicroStation PowerDraft CONNECT Edition Update 4. Sign into the CONNECTION Client to view and apply your Application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
If you would like the full installation of MicroStation PowerDraft CONNECT Edition x64 (Full) Update 4, please follow these steps to download it from Fulfillment Center: 1. Sign in to Bentley.com 2. Browse to Support 3. Select Go To Personal Portal 4. Choose Software Downloads from "My Support" 5. Select the Brand MicroStation and then select the Generation of CONNECT Edition. 6. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation PowerDraft CONNECT Edition x64 Update 4 version 10.04.00.49 Important installation requirements and notices are found in the Readme. communities.bentley.com/.../272502
For the full list of What's New and Changed please refer to the Help section within MicroStation PowerDraft CONNECT Edition Update 2. Please refer to the following link for the Resolved Issues communities.bentley.com/.../32920.list-of-resolved-isssues-for-microstation-powerdraft-update-4-10-04-00-49 in MicroStation CONNECT Edition Update 4. Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
