The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 6 (10.06.00.38) on Fulfillment Center and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition incorporates a number of new capabilities as well as user requested fixes. MicroStation CONNECT Edition Update 6 has also further improved on the new installer technology that was previously introduced for a better and more streamlined installation experience. Please refer to the "What's New Highlights" section below for some of the major product updates and enhancements.
If you currently have MicroStation CONNECT Edition already installed on your computer, you can incrementally download and install MicroStation CONNECT Edition Update 6 from the CONNECTION Client. MicroStation CONNECT Edition Update 6 will replace any earlier versions of MicroStation CONNECT Editions and update it to MicroStation CONNECT Edition Update 6. Sign into the CONNECTION Client to view and apply your Application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
If you would like the full installation of MicroStation CONNECT Edition x64 (Full) Update 6, please follow these steps to download it from Fulfillment Center: 1. Sign in to Bentley.com 2. Browse to Support 3. Select Go To Portal 4. Choose Software Downloads from "My Support" 5. Select the Brand MicroStation and then select the Generation of CONNECT Edition. 6. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation CONNECT Edition x64 Update 6 version 10.06.00.38Important installation requirements and notices are found in the Readme.
You can now change the orientation of each face of a mesh along with any attached normals using the new Change Mesh Normal tool in the Modify Meshes ribbon group.
The following enhancements are made to reality mesh attachments.
In MicroStation, you can now stream reality data associated to a Bentley CONNECT ProjectWise Project.
MicroStation now supports the Scalable Mesh (.3sm) files. Scalable mesh files are suitable for display, analysis and editing of large 3D meshes in CONNECT generation of Bentley design applications.
For the full list of What's New and Changed please refer to the Help section within MicroStation CONNECT Edition Update 6.Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 6. Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
