The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 7 (10.07.00.39) on Fulfillment Center and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition incorporates a number of new capabilities as well as user requested fixes. Please refer to the "What's New Highlights" section below for some of the major product updates and enhancements.
If you currently have MicroStation CONNECT Edition already installed on your computer, you can incrementally download and install MicroStation CONNECT Edition Update 7 from the CONNECTION Client. MicroStation CONNECT Edition Update 7 will replace any earlier versions of MicroStation CONNECT Editions and update it to MicroStation CONNECT Edition Update 7. Sign into the CONNECTION Client to view and apply your Application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
If you would like the setup executable of MicroStation CONNECT Edition x64 (Full) Update 7, please follow these steps to download it from Fulfillment Center: 1. Sign in to Bentley.com 2. Browse to Support 3. Select Go To CONNECTION Center 4. Choose Software Downloads from "My Support" 5. Select the Brand MicroStation and then select the Generation of CONNECT Edition. 6. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation CONNECT Edition x64 Update 7 version 10.07.00.39 Important installation requirements and notices are found in the Readme.
MicroStation now simplifies use of Bing Map data for CONNECTED users. You can set the background maps from the View Attributes dialog in the Background Map section. The simplified method allows a street map, aerial imagery, or hybrid imagery (streets and street names superimposed on aerial imagery) to be used as a background for any 2D or 3D design model that has a Geographic Coordinate System attached.
Bentley LumenRT CONNECT Edition Update 3 in Designer mode is now installed as a Companion Application. This application does not require a separate license and is available to all CONNECT subscribers.
The Publish i-Models dialog now provides an option to select various versions of i-Model to publish.
Place Active Line Terminator now maintains association of the cell with the element when element is moved or rotated.
Ability to create custom line styles by repeating raster images.
Ability to Edit Item directly from a the Edit Item dialog when right-clicking on an element with an item type(s) attached to it.
You can now extrude an element to create a tubular solid or surface using the Solid by Extrusion Along Path and Surface by Extrusion Along Path tools respectively..
For the full list of What's New and Changed please refer to the Help section within MicroStation CONNECT Edition Update 7. Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 7. Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
