The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 9 (10.09.01.01) on Software Downloads and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition Update 9 is focused on product stability and improved operational efficiency for the user.
Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 9. Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
If you currently have MicroStation CONNECT Edition already installed on your computer, you can incrementally download and install MicroStation CONNECT Edition Update 8 from the CONNECTION Client. MicroStation CONNECT Edition Update 9 will replace any earlier versions of MicroStation CONNECT Editions and update it to MicroStation CONNECT Edition Update 9. Sign into the CONNECTION Client to view and apply your Application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
If you would like the setup executable of MicroStation CONNECT Edition x64 (Full) Update 9, please follow these steps to download it from Fulfillment Center: 1. Sign in to connect.bentley.com 2. Choose Software Downloads from "My Support" section. 3. Select the Brand MicroStation and then select the Generation of CONNECT Edition. 4. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation CONNECT Edition x64 Update 9 version 10.09.01.01
Important installation requirements and notices are found in the Readme.
