MicroStation CONNECT Edition Update 10
The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 10 (10.10.00.23) on Software Downloads and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition Update 10 focused on performance improvements and stability for the user.
Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 10.  Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
What's New Highlights
 Usability Performance improvements
    • Performance improvement to the Backstage to reduce the time to switch from Work Area
    • Optimized MicroStation loading with a large number of WorkSets and multiple references from mapped network drives
    • Improved performance on the Properties Dialog when it is open while selecting a cell from the cell library that resides on a network drive
CONNECT Services Ribbon Tab
    • Consolidated CONNECT Services Ribbon tab to make it easier to find all of the services in one location
    • Direct access to CONNECT Advisor
Shared Raster Manager Proxy Settings
    • If you require Proxy Settings for your Rasters when using Raster Manager, the Reality Mesh Proxy Server Settings now carries over these settings.  You can find this option under Reality Mesh Attachments>Attach Reality Mesh>ProjectWise ContextShare Browser>Reality Data Settings.
Geo-Coordination
    • The description of a GCS can now be changed in the Geographic Coordinate System Properties dialog. Also, a new column GeoCS Description is added to the References dialog list box. It displays the description of the GCS, if the reference has one. This will help in identification of geographic coordinate systems, if you have many of them referenced in your model.
LumenRT 10
    • LumenRT Designer Update 10 is now available for use at no cost as a companion product with MicroStation Update 10
 Technology Preview
    • The Pick List Manager for Item Types is now available as a Technology Preview
The Following features will be moving into Commercial Release
    • Item Type Attachment - Ability to attach multiple Item Types to an element at once
    • The Circular Profile Extrusion  tool  -  Allows to quickly create circular extrusion along path
    • Issue Resolution Service – Provides online red line and markup tools to help users in the field (or office) communicate problems with the design. Full commercial release with Update 10.
    • Edit Item dialog - Helps editing Items instance data
Update
If you currently have MicroStation CONNECT Edition already installed on your computer, you can incrementally download and install MicroStation CONNECT Edition Update 10 from the CONNECTION Client. MicroStation CONNECT Edition Update 10 will replace any earlier versions of MicroStation CONNECT Editions and update it to MicroStation CONNECT Edition Update 10. Sign into the CONNECTION Client to view and apply your Application updates.   If needed, please refer to the CONNECTION Client help for more information on installing the update.
Download
If you would like the setup executable of MicroStation CONNECT Edition x64 (Full) Update 10, please follow these steps to download it from Fulfillment Center:
    1. Sign in to connect.bentley.com
    2. Choose Software Downloads from "My Support" section.
    3. Select the Brand "MicroStation".
    4. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation CONNECT Edition x64 Update 10 version 10.10.00.23
Important installation requirements and notices are found in the Readme.
