SIG Virtual Workshop: MicroStation - August 28, 2018 - You're Invited!
Don't miss the MicroStation Special Interest Group’s new virtual series on Upgrading to MicroStation CONNECT Edition. Attendance is complimentary. Choose from two convenient times for each event; both will share the same agenda. Register today!
One Professional Development Hour will be applied to each attendee’s Bentley Transcript for self-reporting. If you missed Part 1, no worries! You can check out the video on the MicroStation SIG Learning Path.
See you online!
Note: When entering sessions, registrants should use the Guest option. Also, be sure your email preferences reflect that you want to receive emails for this SIG. To do this, go to www.Bentley.com > Sign In > View Profile > Edit icon and select the "To edit your communication preferences, click here" (https://www.bentley.com/communication-preferences) option.
