MicroStation PowerDraft CONNECT Edition Update 12 Released
The MicroStation PowerDraft product team is pleased to announce the availability of MicroStation PowerDraft CONNECT Edition x64 Update 12 (10.12.00.42) on Software Downloads and for update through the CONNECTION Client. This version of MicroStation PowerDraft CONNECT Edition Update 12 utilizes CONNECT Licensing so that users can take full advantage of administering and managing their licenses.
Please refer to the following link for the Resolved Issues in MicroStation PowerDraft CONNECT Edition Update 12.  Also, be sure to visit the MicroStation PowerDraft forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
What's New Highlights
Ability to Create Reports from Item Types Within a Current Selection or Active Fence
  • You can now choose to create reports from item type instances attached to elements within the current selection or an active fence. You can do so by setting the Selection Type to By Fence or Current Selection in the Reports dialog.
Technology Preview
Expressions - You can now define and attach an expression to an element's item type. The corresponding value of the expression will display in the element's Properties dialog. Expressions can represent business data which otherwise cannot be graphically represented for an element. Expressions have specific syntax definitions based on their type like arithmetic, concatenation, condition, comparison and so on.
  • Expressions to Derive Data from Lookup Tables- You can now use expression inputs in the Item Types dialog to derive data from lookup tables into an element's item type property definition. Lookup Tables can be lists of data, in excel format, associated with your project.
Moving into Commercial Release
  • Item Types Excel Import/Export
  • Place Label Cell Filter by Element
If you currently have MicroStation PowerDraft CONNECT Edition already installed on your computer, you can incrementally download and install MicroStation PowerDraft CONNECT Edition Update 12 from the CONNECTION Client. MicroStation PowerDraft CONNECT Edition Update 12 will replace any earlier versions of MicroStation PowerDraft CONNECT Editions and update it to MicroStation PowerDraft CONNECT Edition Update 12. Sign into the CONNECTION Client to view and apply your Application updates.   If needed, please refer to the CONNECTION Client help for more information on installing the update.
Download
If you would like the setup executable of MicroStation CONNECT Edition x64 (Full) Update 12, please follow these steps to download it from Fulfillment Center:
    1. Sign in to connect.bentley.com
    2. Choose Software Downloads from "My Support" section.
    3. Select the Brand "MicroStation".
    4. Download the latest release by clicking on the arrow to expand the selection and then on MicroStation PowerDraft CONNECT Edition x64 Update 12 version 10.12.00.42
 Important installation requirements and notices are found in the Readme
