MicroStation CONNECT Edition SDK Update 15
December 8, 2020
The MicroStation SDK team is pleased to announce the release of the MicroStation CONNECT Edition SDK Update 15 (U15).
The most recent release provides several enhancements in the following areas:
  1. Executive Summary
    • Microsoft Visual Studio 2017 Professional (or better) is the default toolset requirement
    • Recompile MDL applications when toolset requirements have changed
    • Incremental updates: APIs, Documentation, Examples, eula.pdf
  2. Documentation
  3. Developer Shell
    • N/A
  4. Includes and APIs
    • Added
    • Updated
      • DgnIModel\publish\IModelPublisherOptions.h (GetRemoveIModelsAfterPackaging, SetRemoveIModelsAfterPackaging)
      • DgnPlatform\Tcb\3dtools.r.h (polyhedronGeodesicDepth, meshFromPointsRemoveLongEdges, maxBoundaryEdgeLength)
      • DgnPlatform\Tcb\tcb.r.h (activeVariation)
      • DgnPlatform\CustomItemType.h (IsHiddenProperty, SetIsHiddenProperty, IsReadOnlyProperty, SetIsReadOnlyProperty)
      • DgnPlatform\DgnAttachment.h (Enforced: DgnAttachment vs DgnModel)
      • DgnPlatform\DgnECInstance.h (CreateReadOnly, SetCreateReadOnly)
      • DgnPlatform\DgnLinkManager.h (DGNLINK_REGIONTYPE_NamedBoundary, DGNLINK_FILTERTYPE_Region_NamedBoundary)
      • DgnPlatform\DisplayHandler.h (CalcElementRange)
      • DgnPlatform\ECReportNode.h (Many: ItemType and ReportResult options)
      • DgnPlatform\IViewDraw.h (MATSYMB_OVERRIDE_FallbackRenderMaterial)
      • DgnPlatform\Light.h (GetNaturalFilmResponseExposure, SetNaturalFilmResponseExposure)
      • DgnPlatform\NamedBoundary.h (FindOrphanByName)
      • DgnPlatform\ParametricModeling.h (ByLevelSymbologyFlag)
      • DgnPlatform\PickList.h (SetName, SortValues, SavePickListLibToDgnWithChanges)
      • DgnPlatform\RenderStore.h (RenderStore_VueSetup)
      • DgnPlatform\TextTableHandler.h (GetSizeLock)
      • DgnPlatform\WorkSet.h (Eh: 1108579. AddProperty, AreAllPropertiesLoaded, RemoveProperty)
      • GeoCoord\BaseGeoCoord.h
        • WGS84ConvertCode, GenConvertCode
        • InitTransverseMercator, originalIfPresent, allowUnitsOverride, ReprojectStatus
        • GetLinearTransformECEF, CartesianFromCartesian, CartesianFromECEF
        • GetGeoTiffKeys, GetMathematicalDomain, GetMathematicalDomainExtent
      • GeoCoord\BaseGeoDefs.r.h (GEOCOORDERR_GeoCoordNotInitialized, GEOCOORDERR_InvalidGeodeticTransform)
      • Mstn\MdlApi\dgnlib.h (ElementTemplatesOnly, ItemTypesOnly)
      • Mstn\MdlApi\dlogids.r.h (GCS macros)
      • Mstn\MdlApi\msinput.fdf (SetEnterIdleFunction)
      • Mstn\MdlApi\rmdlgids.r.h (Menu entries: GCS and Raster)
      • Mstn\MdlApi\userpref.r.h (useDarkTheme, dropLineStyleWarning)
      • Mstn\cmdlist.r.h (CMD_PLACE_BLOCK_CENTERED)
      • Mstn\MicroStation.r.h (ACTIVEPARAM_VARIATION)
      • Mstn\MstnDefs.h (CAPABILITY_TEXT_INSERTSTACKFRACTIONS)
      • mki\AssertToolSet.mki (VS2019_NO_SHORT_NAME, DONT_SET_NET_FRAMEWORK_FOR_VS2017)
      • mki\CaptureCommandEnv.py (s_sub8dot3PathExclusionList)
      • mki\common.mki (BMAKE_CLEANER_ENVIRONEMNT, DOTNET_SDK_PROJECT_BUILD)
      • mki\VsDevCmdImport.bat (VS2019_NO_SHORT_NAME)
      • mki\winntmdl.mki (Defect 1108605 - Corrections to ntTools macro)
  5. Examples
    • Added
    • Updated
      • Elements\ManagedToolsExample
        •  KEY-INS
          • TOOLSEXAMPLE BOOLEAN DIFFERENCE
          • TOOLSEXAMPLE BOOLEAN INTERSECTION
          • TOOLSEXAMPLE BOOLEAN UNION
          • TOOLSEXAMPLE EXAMPLEVIEW TOOL
          • TOOLSEXAMPLE MODIFY ELEMENTS
  6. Libraries
    • None
  7. Requirements
  8. Known Issues, Bug Fixes, Breaking Changes
    • The MicroStation CONNECT Edition SDK installer version may differ slightly from the SDK build version. This is cosmetic and either version number is acceptable.
    • Review Resolved Defects: MicroStation CONNECT Edition Update 15 - Resolved Issues
    • Recompile MDL applications when default toolset requirements change
  9. Release Notes
    • It is recommended to modify the Desktop and/or Start Charm/Menu shortcut properties to enable: "Run as Administrator".
      This ensures any Windows protected locations can be created and modified properly.
    • MicroStation CONNECT Edition SDK releases generally are available within 2 weeks of a respective closely paired MicroStation product release
    • To ensure maximum application compatibility and stability of your applications:
      • Make sure to use the latest MicroStation CONNECT Edition SDK and a (closely) matching MicroStation product version
      • It is highly recommended to recompiling existing applications for each new MicroStation product and SDK update release
    • If Breaking Changes are provided, MDL applications will require recompilation
  10. Resources
