Title: Coffee Corner: MicroStation - Tables and ReportingPresenter: Brad Hodor, Civil Engineer, Civil Solutions Inc, and Scott Saltzmann, Director, Software Engineering and Construction, Civil Solutions IncDate and Time: August 24, 2021
Register Now!
The August 2021 Coffee Corner on Tables and Reporting with start by utilizing the Query Builder tool to isolate our electrical elements into a Report Definition.
Query Builder
Once our search definition is complete, we will focus on setting up the Report Table to display the element properties we want in the final Table. When setting up the Report Table we will show how to use Filters and Condition Editor to narrow our reporting of Table elements.
Creating Reports
With the final reporting elements completed, we will move onto formatting the data we are returning from the elements. Once the final report is complete, we will show how to place a table with an Association to the reporting elements from the Query Builder criteria.
Building Tables
MicroStation Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
