Title: Coffee Corner: MicroStation - Batch Processes Using ScriptsPresenter: Joel Arguelles, Roadway Design Engineer, Mesa Integrated Solutions and Shawn McGaffick, Senior Manager, Content Development, Bentley SystemsDate and Time: Tuesday, October 26, 2021 at 11:00 am EDT
Register Now!
The October MicroStation Coffee Corner will discuss automating the update of design files through a Batch Process using scripts.
Design files can be updated using Batch Process to streamline and speed up the process with a desired set of output files. This session will review the step by step process to run Batch Processes.
MicroStation Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
