MicroStation CONNECT Edition SDK Update 17.2
March 7, 2023
The MicroStation SDK team is pleased to announce the release of MicroStation CONNECT Edition SDK Update 10.17.02.09.
The current release provides several enhancements in the following areas:
Executive Summary
Keep Current
Requirements
MicroStation CONNECT Edition SDK native (C/C++) and managed code (.NET add ins) development requires:
Bentley Visual Studio Templates
Microsoft Visual Studio Configuration Recommendations
Visual Studio - Workload Dependencies
Visual Studio - Installing and Configuring
Visual Studio - Toolset location Changes
Note: Microsoft recommends binding 1 Toolset (version) per 1 Development Shell (environment instance)
Release Notes
  • General
    • Some CHM files are Missing in this release of the SDK and can be obtained and manually installed from here.
    • Modify the Desktop and/or Start Charm/Menu shortcut properties to enable: "Run as Administrator"
    • MicroStation CONNECT Edition SDK releases are generally available within 2 weeks of a respective closely paired MicroStation product release.
    • To ensure maximum compatibility and stability of your applications:
      • Recompile custom applications when Microsoft Visual Studio version changesor Breaking Changes are mentioned.
  • Bug FixesReview Resolved Defects: MicroStation CONNECT Edition - Resolved Issues
  • Breaking Changes - N/A
Changes
MicroStation Developer Shell
SDK Root
  • N/A
Bin
  • SDKCommonEnv.bat (BLI 1090328 - Add VerifyRequirements)
  • SDKMacros.bat (BLI 1090325 - Add SDKMacros)
  • SDKPrefs.bat (BLI 1090328 - Add VerifyRequirements)
Documentation
  • Incremental API Updates. See: Include section (below) and ChangeLogs
Examples
  • Added
    • DgnEC\DgnECManagedPropertyPaneExample (BLI 1018729 - Add SDK Example Show Properties of DgnEC Instance in Property Pane)
  • Updated
    • examples\Elements\SteelMaster (Bug 1090301 - Fix Steel build dependency issues)
    • examples\Miscellaneous\steel (Bug 1090301 - Fix Steel build dependency issues)
Include
  • Constraint2d\Constraint2dCoreAPI.h
    • Add Enum VertexType (Centroid)
    • Add Enum Constraint2dType (EqualAngle)
  • DgnPlatform\CustomItemType.h
    • Add GetAccessStringFromContext, GetInstanceClassFromContext, IsContextAvailable
  • DgnPlatform\DgnECTypes.h
    • Add DgnECExtendedType::DirectionAngle
  • DgnPlatform\DgnPlatform.h
    • Add MAX_MATRIX_DATA_DOUBLE, MAX_MATRIX_DATA_INT
  • DgnPlatform\DgnPlatform.r.h
    • Add hideTextFieldBkgrnd
  • DgnPlatform\DgnPlatformErrors.r.h, Add:
    DGNMODEL_STATUS_TNodeMaxLengthError
    DGNMODEL_STATUS_InvalidPixelsFormat
    DGNMODEL_STATUS_OversizedMatrixData
    DGNMODEL_STATUS_InvalidNumValueData
    DGNMODEL_STATUS_InvalidBSPLINECURVE
    DGNMODEL_STATUS_InvalidBSPLINESURFACE
  • DgnPlatform\DisplayFilter.h
    • Add ViewFlag_TextFieldBkgrnd
  • DgnPlatform\MaterialSettings.h. Add:
    MAPTYPE_PBRClearcoatFlatten
    MAPTYPE_PBRClearcoatIntensity
    MAPTYPE_PBRClearcoatNormal
    MAPTYPE_PBRClearcoatRoughness
    MAPTYPE_PBRClearcoatTint
    GetClearcoatColor
    GetClearcoatColorR
    GetClearcoatFlatten
    GetClearcoatIntensity
    GetClearcoatNormalMapScale
    GetClearcoatRefract
    GetClearcoatRoughness
    GetPBRClearcoatColor
    GetPBRClearcoatColorR
    GetPBRClearcoatFlatten
    GetPBRClearcoatIntensity
    GetPBRClearcoatNormalMapScale
    GetPBRClearcoatRefract
    GetPBRClearcoatRoughness
    SetClearcoatColor
    SetClearcoatFlatten
    SetClearcoatIntensity
    SetClearcoatNormalMapScale
    SetClearcoatRefract
    SetClearcoatRoughness
    SetPBRClearcoatColor
    SetPBRClearcoatFlatten
    SetPBRClearcoatIntensity
    SetPBRClearcoatNormalMapScale
    SetPBRClearcoatRefract
    SetPBRClearcoatRoughness
  • DgnPlatform\TextTableHandler.h
    • Add: TableMinorId
  • DgnPlatform\TextTableStyle.h
    • Add SortTableStyles
  • Geom\DPoint3dOps.h
    • Add ConvexHullXY, AreaPerpendicularToUpVector
  • Geom\Polyface.h. Add:
    CreateTrianglesInHoles
    ExtractBoundaryStrings
    ExtractTopologicalBoundaryStrings
    HoleFillingOptions
    IsIncludeOriginalFacets
    IsPlanarWithinSuperfacets
    IsValidEdgeCount
    IsValidPerimeter
    NormalizedUpVector
    TryGetMaxSingleFacetLocalXYLength
    TryGetMaxSingleFacetParamLength
  • Mstn\Constraint2dElement\ConstraintHandlerBase.h
    • Add _DoModifyAgendaEntries
  • Mstn\MdlApi\dlogids.r.h
    • Add TOGGLEID_OpenWithoutRef, MENUSEARCHID_ImportSub_KML, ICONCMDID_KmlImport
  • Mstn\MdlApi\helpids.r.h
    • Add HELPID_PULLDOWN_InpSub_KML
  • Mstn\MdlApi\rmdlgids.r.h. Add:
    ERROR_NotXAMIS
    ERROR_NotXWCS
    ICONCMDID_attachAMIS
    ICONCMDID_newAMIS
    ICONID_attachAMIS_16x16
    ICONID_newAMIS_16x16
    MENUSEARCHID_RMDlgAttachAMIS
    MENUSEARCHID_RMDlgAttachWCS
    MENUSEARCHID_RMDlgEditXAMIS
    MENUSEARCHID_RMDlgEditXWCS
    MENUSEARCHID_RMDlgNewAMIS
    MENUSEARCHID_RMDlgNewWCS
    MENUSEARCHID_RMDlgPopupEditAMIS
    MENUSEARCHID_RMDlgPopupEditWCS
    MISCID_AMISATTACHBALLOONSTRFORGA
    MISCID_AMISFileFilter
    MISCID_AMISFileSInvalidGCS
    MISCID_AMISNEWBALLOONSTRFORGA
    MISCID_ATTACH_WCS
    MISCID_EDITAMIS
    MISCID_EDITWCS
    MISCID_NEW_WCS
    MISCID_WCSFileFilter
  • Mstn\cmdlist.r.h
    • Add CMD_SET_PLACEMENTPOINTNAME, CMD_REFERENCE_LOADREFERENCE
  • Mstn\MicroStation.r.h
    • Add quickLoadRef
Library
  • N/A
Migration Tools
  • N/A
MKI
  • Various make files (*.mki)
    • mki\CaptureCommandEnv.py (Updated Visual Studio version numbers and build ids)
Updates and Enhancements
Bugs
  • Bug 946864 - VBA File properties documentation- Update Design File Property Descriptions (typical)
    ActiveDesignFile.Author
    ActiveDesignFile.Comments
    ActiveDesignFile.Client
    ActiveDesignFile.Company
    ActiveDesignFile.DateLastPlotted
    ActiveDesignFile.Title
    ActiveDesignFile.Manager
    ActiveDesignFile.Subject
  • Bug 974065 - Update Constraint2ddemo.cpp to call BeFileName--GetDirectoryName vs GetSystemDirectoryW
  • Bug 1086590 - Fix Copyrights for Audit
  • Bug 1090301 - Fix Steel build dependency issues
Backlog Items
  • BLI 1090325 - Add SDKMACROS
    • InstallLogs - list and navigate to Bentley installer log location
    • FILEDETAILS - list files: long names, short names, MD5, last modified time
    • FILEMODS - Arg1: list file (types) modified in past Arg2: (or future) X number of days optionally ordered by Attribute
    • FILETYPES - quantify file types under current folder
    • FILEVERSIONS - list library file version metadata
    • SHORTFILE - list 8DOT3NAME for all files under current folder
    • SHORTFOLDER - list 9DOT3NAME for all folders under current folder
  • BLI 1090328 - Add SDK Requirements
Resolved Issues (Product)
Resources
Related
Available Languages: Chinese, EnglishGerman
