Title: Coffee Corner: MicroStation - Global - What you're losing if still below MicroStation U14
Date: Thursday, March 16, 2023
Time: 11:00 AM Eastern Daylight Time
Presenters: Eduardo Mendonca, Neha Dendukuri
Register Now!
Do you remember what the world was like in 2019? “Only” four years ago, but your life and work were probably vastly different then, weren’t they? What about five years ago? Ten? Well, if you are a 2D Drafter or 3D Modeler who still uses a MicroStation version below U14, did you know that you can perform your tasks better, solve problems more efficiently, and be more CONNECTED?
In the upcoming Coffee Corner, see "What's New" from MicroStation Update 14 to the newest Update 17! In addition to the improved stability, increased performance, and continued commitment to software security, we are much more interoperable, collaborative, and geared towards iTwin services.
If you no longer work the same way as you did years ago, why still stick with the same old software version? Come and check what you're missing out on, including Clash Detection, Cloud Services, Component Center, Parametrization, iTwin Design Review, and much more!
Bentley Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
