Title: Coffee Corner: MicroStation (Global) - Workspace Management and Configuration II
Date: Thursday, May 18, 2023
Time: 11:00 AM Eastern Daylight Time
Presenters: Alicia Rodriguez, Senior Application Engineer – MicroStation, Bentley Systems, Inc. - Eduardo Mendonça, Application Engineer, Facilities Engineering, Bentley Systems, Inc.
Register Now!
In this second session on Configuration in MicroStation CONNECT Edition, you will learn how to create, manage, and enforce your project standards in different levels of configuration and across Bentley applications. We will show a practical example of how to work with one configuration. You can work with multiple sets of data in your project, taking advantage of shared standards and templates.
Bentley Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
