MicroStation 2023 SDK (23.00.01.26)
September 27, 2023
The MicroStation SDK team is pleased to announce the commercial release of MicroStation 2023 SDK (23.00.01.26) for use with recently announcedMicroStation 2023 (23.00.01.44).
Executive Summary
Keep Current
Requirements
MicroStation SDK native (C/C++) and managed code (.NET add ins) development requires:
Bentley Visual Studio Templates
Microsoft Visual Studio Configuration Recommendations
Visual Studio - Workload Dependencies
  • .NET Desktop Development
  • Desktop development with C++ (Provides: DIA SDK)
  • Universal Windows Platform development (Provides: Windows 10 SDK, or Download)
Visual Studio - Installing and Configuring
Visual Studio - Toolset location Changes
Note: Microsoft recommends binding 1 Toolset (version) per 1 Development Shell (environment instance)
Release Notes
  • General
    • Some CHM files are Missing in this release of the SDK and can be obtained and manually installed from here.
    • Modify the Desktop and/or Start Charm/Menu shortcut properties to enable: "Run as Administrator"
    • MicroStation SDK releases are generally available within 2 to 4 weeks of a respective closely paired MicroStation product release
    • To ensure maximum compatibility and stability of your applications:
      • Recompile custom applications when Microsoft Visual Studio version changesor if Breaking Changes are mentioned
  • Bug FixesReview Resolved Defects: MicroStation - Resolved Issues
  • Breaking Changes - N/A
Changes
MicroStation Developer Shell
SDK Root
  • N/A.
Bin
  • N/A
Documentation
  • Incremental API Updates. See: Include section (below) and ChangeLogs
Examples
  • Updated SDK .NET Example App Config and Projects to: TargetFrameworkVersion v4.8
  • NOTE:
    • In DgnEC context, SrNo is an abbreviation for "Serial Number"
    • Project Temp Variables containing version numbers within paths may have changed. E.g. From: 10.0.x, To: 23.0.x
Include
  • BeSQLite\BeSQLite.h - Improve Type Integrity: SqlValueP
  • DgnPlatform\Tcb\3dtools.r.h - Add: allowOpenProfile
  • DgnPlatform\AssocRegionHandler.h - Add: m_ignoreFloodIfSeedInHole
  • DgnPlatform\DgnLinkManager.h
    • Add: CloneLinkTree, CreateNewLinkTreeFromBranch
  • ECObjects\ECSchema.h
    • Update Type Integrity: WStringKey key assignment operator
  • GeoCoord\BaseGeoCoord.h - Add: CartesianFromCartesian2D
  • Geom\ClipPlaneSet.h
    • Update: Formatting, Spelling and Documentation (typical)
    • Rename (last) Parameter: IsSphereInside
    • Add: ClipPath, ClipCurveVector, SortByIndexAndFraction, m_allowSharpestCorners, SetAllowSharpestCorners, GetAllowSharpestCorners
  • Geom\CurveVector.h
    • Update Type Integrity:CurveVectorPtr, AppendSplitCurvesByRegion, AppendSplitCurvesByPlane
    • Add Parameter: CloneBetweenDirectedFractions - usePartialCurves
  • Geom\MSBsplineCurve.h
    • Add: AreSameKnotVectorsNormalized
  • Geom\Polyface.h
    • Add: BuildConvexClipPlaneSet
  • Mstn\Constraint2dElement\ConstraintHandlerBase.h
    • Add: _GetAnchoredVetexPosition, _GetAnchorPoint, _UpdateAnchorPoint
  • Mstn\MdlApi\dlogids.r.h
    • Add: ICONID_ShowCellProperties, TOGGLEID_ShowCellProperties, SYNONYMID_ACSToggleSet, HOOKITEMID_Toggle_ShowCellProperties
  • Mstn\MdlApi\dlogitem.h
    • Update Logo: BentleyBlack
  • Mstn\MdlApi\msinput.fdf
    • Add: mdlInput_sendSynchronizedKeyinExtended, mdlInput_pythonMainLoop
  • Mstn\MdlApi\rmdlgids.r.h
    • Add: ICONID_attachWCS_16x16, ICONID_newWCS_16x16, ICONCMDID_attachWCS, ICONCMDID_newWCS
  • Mstn\MdlApi\userpref.r.h
    • Add: NUM_DEFAULT_RECENT_MENUS, recentsButtonsMaxCount, useTextEditHilite, textEditHilite
  • Mstn\cmdlist.r.h
    • Add: CMD_DIALOG_TOOLBOX_LEVELS, CMD_DMSG_FOCUSDIALOG_TOOLBOX_LEVELS, CMD_DMSG_DUMP_TOOLBOX_LEVELS
  • TerrainModel\Core\IDTM.h
    • Add: ~IDTMVolume
Library
  • N/A
Migration Tools
  • N/A
MKI
  • CaptureCommandEnv.py - Update: toolSetToMSVCVersionMap
  • Update Type Integrity: BBPYTHONCMD
    • dlmlink.mki, llvmlib.mki, MultiCppCompileGoGCC.mki, VsDevCmdImport.bat
Resources
