The task icon cannot be opened via the function column. Does anyone know what that could be?
from your question, it's not very clear what your problem is. Can you please follow this forum best practices and to specify used product, its version and API / language? Also, what do you mean by "task icon" and "function column"? Can you share e.g. a picture?
With regards,
Jan
it's about Microstation V8i SELECTseries 4. see picture. unfortunately it is in German.
Hi Joël,
it seems your question is not about programming, so it does not belong to this forum.
I recommend to move it MicroStation forum. BTW Do you know there is also German MicroStation forum?
To move existing discussion to another forum, use More > Move tool available under your original post.
P.S. Also, it's weird to take a picture of monitor. Are you aware of screen capture functionality in Windows (print screen key or Win + Shift + S in Windows 10)?
