attach model as reference file - interactive option
The MicroStation documentation indicates that if you drag a model into a view, it will bring up a window to allow you to attach it as a reference file using the interactive method. When I try this and select Interactive, it does not prompt me to enter a data point to locate the model, it just slaps it somewhere and then I have to move it manually. Is this a bug or am I missing something?
Stephanie
