I have a client who's dgn file has stop displaying the drawing elements this morning. They state the drawing was fine the first time it was open and later when opening it, the drawing no longer displayed anything. I am getting the same results when I open the file. When viewing the levels display the drawings levels still show as being active and used in the drawing. I have looked at the level manager and the display column for the levels used are checked. I have tried edit>select all and nothing highlights in the drawing. Any ideas as what is wrong and how to correct is greatly appreciated.
I panicked, realised I'd turned off all the View toggles ...
Ronnie Grimes
What you describe with the level showing twice in Level Manager list box suggests that the elements are cells.
Try going to View Attributes and try to change the clip volume & clip front/back. You can also try to toggle the Displaysets attribute. Possibly tags attribute as well.
Otherwise, right click on one of the used levels in Level Manager go to properties and the the Usage tab. You should see a list of elements for that level. It's possible you have a file with multiple models. The active model may have nothing in it and the elements are contained in another model.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
