So I inherit this dgn. I ref'd in another dgn with a lot of text in it, then merged it into the master dgn to get it all into one file. The text was not annotation. I made it so and it went wild, the size was huge. I changed the height/width from 2.4 to 0.06 like it was supposed to be, got it all cleaned up, supposedly. But, everything is still too large by a factor of twelve. My drawing is 40 scale - instead of 2.4 height text, it is all 28.8. if I edit a piece of the text then open the text style using the magnifying glass on the text style dialog that opens up with the text editor it says that the height/width is 0.06. the MU/SU of each was USF/Custom (1000=12 US Survey Inch) (don't ask me why, I didn't set it, all of our dgn's are set this way) and I had set both to USF/USI (the custom was some weird thing is there a way to fix this or do I start over?
There are annotation cells that are also all screwed up – in the opposite direction. They are so small they look like points, even though their scale is set to 1.00 and the annotation scale is 40. For some reason they have rectangular handles that far exceed what you see on the display (about 90 MU x 12 MU). I am punting and starting over with a fresh dgn.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
