Conversion Issue DWG (Autocad) to DGN (Microstion)
Guys,
We are doing workshare with other country. The problem was occured when we had converted the drawings from Autocad to Microstation V8i. While doing the conversion from DWG to DGN, one of the autocad font 'INTL ISO.SHX' is transfered into Microstation file named 'INTL ISO.TTF'. The Problem is that we can see the text in order from our side but unfortunatly in other side they are not. while opening the file from their side all the text are converting from INTL ISO to Simplex and size of the text is also increases. I have found the location of the font style which is transfer from DWG to DGN but it is in under temp folder in my local drive. Pleasehelp to resolve this issue otherwise i have to change all the font into simplex :(
