Is there a way to "convert" a raster clip boundary to microstation geometry? With or without VBA I don't really care. If it requires VBA does anyone alreay have code to accomplish this?
Thanks in advance,
Christmas May
Unknown said:Is there a way to "convert" a raster clip boundary to MicroStation geometry?
I don't have an answer for plain old MicroStation, but for MicroStation VBA your answer is in VBA help for the Raster object: Raster.ClipBoundary yields a RasterClipBoundary...
A RasterClipBoundary is a closed, non-intersecting shape that defines the borders of a Raster. Only the part of the Raster inside the clip boundary is visible. It is also a VertexList and as such, a program can access, insert, remove and modify the ClipBoundary vertices
If you take the VBA route, post further questions to the MicroStation Programming Forum.
With V8i you can snap and trace around the edges of a raster and create a closed polygon geometry on an active level is that what you wanted ?
Lorys
